I'm sorry, I'm going to ask a few more questions, Questions: Curtain Settings Section: S1- Header transverse reinforcement - Do I have to tick the option Use Left-Right header transverse reinforcements in Vr calculation according to TDY2007-3.6.4? Since it is necessary to determine according to the condition of the transverse reinforcement of the body inside the wall end along the Critical Wall Height (3.6.4.1 and 3.6.4.2), can the program make calculations and drawing details according to 3.6.4.1 and 3.6.4.2? If I check it, does it include Vr in the places other than the Critical curtain height? Q2- Why is the ---Accept body transverse reinforcements present in the header--- option needed? Is it an option for the existing structure, not the new one? S3- He mentioned that for the option ---Built-in support at the lower end---, the lower end of the curtains without vertical continuity will be calculated as recessed. I know the program warns as a geometry check when there is no vertical continuity. How does this option benefit the user? Q4- ---Ratio of head reinforcement to total reinforcement--- option: how does it benefit us? What value do I need to enter if I only want the regulation value to be applied? Q5- ---Header region length---When do we need the Find program or Set user option? If the user chooses a smaller value than TDY, does it still apply? According to the entered value (ie, according to the regenerated wall end), all reinforced concrete calculations and other relevant data marked in the parameters (Ratio of Head reinforcement - total reinforcement, Consider the body transverse reinforcements in the header, Head transverse reinforcement - Use Left-Right header transverse reinforcements in the calculation of Vr) ) according to interactive recalculation? Q6- How can I include a column of the same thickness adjacent to the wall as a wall end in the analysis? Then drawing? Reinforcement Selection: S7- Reinforcement definitions in Shear Reinforcement selection are given as Vertical, End region vertical, Stirrup, End region stirrup How can we determine the Horizontal Body reinforcement? Pitch Parameters Section: S8- ---Min tip pursantaj--- and ---Min body pursantaj--- when there is ---Min pursantaj (longitudinal-transverse)--- and ---Max pursantaj--- why given ? S9- According to TDY2007, the pursantage value for the Critical curtain height should be 0.002 at the minimum, while it should be 0.001 for the outside. However, only 1 value ---Min tip price---can be specified in the parameters. In this case, is it possible that we cannot take one of them into consideration? S10- Does it not control the curtain thickness under any circumstances?
