Curtain openings do not come regularly
hydrkrmn
CURTAINS OVER THE CURTAIN EXTENSIONS ARE GIVEN SEPARATELY. I WISH YOUR HELP ON THIS MATTER. ONE COLUMN APL. SOME OF THE PLAN AND THE DETAIL OF CURTAINS AND COLUMNS ARE GIVEN OUTSIDE. GOOD WORK...
Hello, In order to get the multi-floor detail drawings of the curtains correctly, define the parameter "Continuously accept small beams/curtains with angle difference" as 20 degrees in the General Reinforced Concrete Parameters. In order not to give the details of the basement curtains outside, select the perimeter curtains on all floors and in the Reinforcement tab in the Curtain settings " Basement floor perimeter" Select the "curtain" option. You can make your settings this way and get the drawings.
