Curtain lower end fixed backing ?
miralay
Good work. When we define raft flooring, is it necessary to mark the lower end of the curtain, the built-in support?
"miralay":1gs17l6w" said:
Good work.When we define raft flooring, do we need to mark the lower end recessed bearing?
Hello, "Curtain lower end recessed bearing" option is checked by default, it should be left checked in normal condition. If you uncheck it, the system cannot be resolved message will appear.This option can be removed if desired for a special case such as connecting the wall only to the columns, in case there are columns at both ends and beams below the wall that does not continue with the foundation.
