CURTAIN HEADER ZONE
coskun3561
Hello; The headboard areas on the carrier curtains that continue throughout the building get smaller on the upper floors. This shrinkage can cause problems in connecting the reinforcements in production. As far as I can see, the masters continue with their own comments. Is there a way to maintain the size of these zones in the same way on the upper floors? I couldn't find it in the program. Good luck with
"coskun3561":1u7wh5t7" said:
Hello; The headboard areas in the carrier curtains that continue throughout the building are getting smaller on the upper floors. This shrinkage can cause problems in connecting the reinforcements in production. As far as I see, the masters continue with their own comments. Is there a way?
I define vertically continuing curtains from the column tab. Cannot change the length of the header region in the column properties.
"coskun3561":om0wzl5v" said:
I define vertically continuing curtains from column tab. Heading area length cannot be changed in column properties.
If you define it as panel, you can change it. It is recommended to define curtains as panel objects and model them as shells.
