Curtain head reinforcement
instinst
Hello, I'm going to ask a question that is not related to idecad, it would be appreciated if you could help. it says use at least 4fi 14 in the screen title in the directing. well, is there a limitation on the diameter of the reinforcement you will use in the curtain header, for example, can I use 6fi12 instead of 4 fi 14? After all, is it not a rule given to provide the necessary pursantan?
"instinst":9k6hog3a" said:
hello, I'm going to ask a question that is not related to idecad, if you can help it would be appreciated. In the directive, it says to use at least 4fi 14 in the curtain title. So is there a restriction on the diameter of the reinforcement you will use in the curtain title, for example instead of 4 fi 14 Can I use 6fi12 after all, isn't it a rule given to provide the necessary pursantage
Minimum pursantage values are given separately with 4fi14 for the curtain end regions. If it were as you said, minimum 4fi14 would not be written. Similar limitations apply to columns as well. It is written to use 6fi14 or 4fi16. It is also written in TS500 that a minimum reinforcement of 14 should be used for columns. In this context, it seems mandatory to use a minimum of 14 in the wall header areas.
