Curtain group bending design.
ottomancagatay
There are L curtains in the project, I created a curtain group, the controls are very high as a result of the curtain group bending design, the structure has a very broken architecture, can we ignore this problem? Or what is your suggestion?
Hello there; There are 8fi/14 in the lower floors and 4fi/14 in the upper floors in the curtain header areas. The distance between two reinforcements in the header areas on the upper floors must be at least 25fi (stirrup diameter). In order to meet this condition, there must be 8 reinforcements in total in the header area. In polygonal curtains, the head reinforcements can be designed according to 10 percent per thousand. It may also be appropriate to increase the reinforcement diameters in the header areas on the lower floors to 16 or 18 mm to be sufficient. Best regards...
