Curtain Cut Safety
mert62
Hello, in the project I added, P06 and P10 curtains give a cut-off security error. Stirrup tightening etc. was not a solution, and I could not understand why there was so much cutting force. The strange thing is that this project saved ide 7 without even tightening and got municipality approval. Could you please review?
Re: Curtain Shear Safety (Attached)
"mert62":30jg3jio" said:
Hello, P06 and P10 curtains give cut safety error in the project I added. Stirrup tightening etc. is not a solution, why is there so much shear force? The strange thing is that this project was saved in ide 7 without even tightening and got municipality approval. Could you please review it?
Hello, Model the elevator shaft without elevation on the curtains and with the raft foundation flat
Good work
Re: Curtain Cutting Safety (Attached) First of all, thank you for your reply, Mr. Levent, but how accurate is this approach in terms of engineering? Also, what is the reason for ide 7 recovery?
Re: Curtain Cut Safety (Attached)
"mert62":2ohcp3l4" said:
First of all, thank you for your answer, Mr. Levent, but how accurate is this approach in terms of engineering, without taking into account a curtain and a raft that will be applied on-site. We analyze and draw manually? Also, what is the reason why it saves in ide 7?
-Since the side walls and bottom plate of the elevator pit are generally made in raft thickness in practice, it can be modeled as described in the link. -Can you add the project data of version -7? Good studies
"Levent Özpak":1fsfaqvf" said:
"mert62":1fsfaqvf" said:
First of all, thank you for your answer, Mr. Levent, but what does this approach mean in terms of engineering? We analyze and draw manually, without taking into account a curtain and raft that will be applied in the right place. Also, what is the reason why it saves in ide 7?
- Since the side walls and bottom plate of the elevator pit are generally made in raft thickness in practice, it can be modeled as described in the link. Could you add the project data of version -7? Good work
I added the detail Mr. Levent
"Levent Özpak":nub8sdmx" said:
"mert62":nub8sdmx" said:
... I added the detail Mr. Levent
ide8demo. Can you add the *.ide7 extension project file that you said you saved from version 7?
Since I opened and saved the ide 7 file in the demo version, the other one in this format is not available at the moment, as you can see, it saves this ide 7 drawing in the project I uploaded, Mr. Levent.
"mert62":21utdujn" said:
... Detail I added Mr. Levent
[ /quote] You added the project file made in ide8demo. Could you add the project file with the *.ide7 extension that you said you saved from version 7?
Since I opened and saved the ide 7 file in the demo version, the other one is not available in this format right now, as you can see, it saves it in the project I uploaded. ide 7 drawing Levent bey
Curtains do not save even when analyzed in version 8.62 in the last project you added. When you add the ide7 extension file or by mail to destek@ideyapi.com.tr When you send it, we will examine it in detail. Good work
take it easy, in this project with bks 1.5 and floor h.4.9 m, although the concrete class sections and reinforcement diameters are very good, no matter what I do, the curtains and some beams in the basement do not dry.... The project is attached
