Curtain Cut Safety Not Provided
unlboss
Friends, only curtain cutting safety is not provided in the project. I couldn't fix it if I did. I would be very happy if there is a friend who can help. I would appreciate it if you could review the project in general and indicate the areas you see missing. Good work to everyone.
I suggest you solve a semi-rigid diaphragm. Then there is no problem with curtain cuts. There are problems with some beams and floors, but you'll see. Also, your ground safety value is incorrect. Multiply by 10. You made a unit error. In addition, the closer the R coefficient is to 6, the more you will force the curtains in terms of earthquake predicament. I haven't looked into anything else in detail. Take it easy, good work.
Hello In addition; --top rigid basement floor numbers should be -4 and -2 --remove "flooded/non-continuing panel on all floors" on the outer curtains of the building --solve it together with the stairs Take it easy Ünver ÖZCAN
