In my first project, I made the beams 30-50 out of the usual 30-50, because it was said that a beginner should look at the beams, so I made 30-50 out of fear rather than courage.[/ quote] I couldn't understand what you mean by conventional. If it's a habit, it's a good habit. A lot of people smoke, it's a habit, but it's a bad habit. When looked at, it only seems to be harmful to the drinker, but now we all know that it is not so. It seems that the static design that you have done here will only return you (positive-negative) in project design, but it is not. People will live in the building you build. You wrote out of fear, not courage, but you chose a different fear for yourself.
Instead of fear of what people will say, the fear of what might happen to the people who will live here is a more positive fear in terms of creating a good project.
"civilman":2pjvmqk5" said:
How much do I need to take the flooring loads at the workplace?
TS498 says the live load for shops, restaurants, etc. is 500 kg/m2. Same for canteens, light workshops, etc. So it should be 500. I think. It is called 200 for shops up to 50 m2 in residences, but I think that there are not many such places today (since I have not seen the architectural project). Even if there are shops under 50 m2 in the architectural project, in general, these are combined and the shop is converted into a market etc.
" civilman":2pjvmqk5" said:
You said that ribs should not cut the ventilation and chimney cavities. I show those parts as slabs, then specify the space in the autocad and put the reinforcement plan on the edge of the gap and translate it. How about without cutting the ribs? .........Because the beams that you wanted me to attach perpendicular to the curtain were cutting ventilation, I couldn't connect them upright.
In such flooring systems, holes and tears in the flooring are very important. These details, whose location is not well calculated, cause significant problems in the hands of uninformed people in practice. Drilling, breaking the beams, finishing the ribs without bracing. Since such gaps are especially at the bottom of the columns, the consequences of the error will be even greater. Therefore, you should see the design clearly and design the floors or ribs accordingly. For example, when you have a 2.5 m curtain, if there is a 1.5 m ventilation gap on its side, it means that you will cut at least 3-4 ribs here. In this case, it may be more correct to turn the ribs in the other direction. Or you don't lay low, but they can do low laying randomly at the construction site. Or something else, they may start to break the wrong places to place the wc stone.
Is it appropriate that I will be laying continuously and still do the superstructure interactively?
I think that by continuous flooring you mean the continuous foundation beam. There is no superstructure interactive solution for continuous foundations. I wish you success and good work N. YILMAZ
