muratkanici
Hello, In general, a few problems I encounter in all my projects, 1) While the total length of the sprout frosts is basically 179 cm, it is given as 180 cm in the curtain detail drawings. 2) While the total number of curtain rod reinforcements is 136, 134 are given in the column application plan and curtain detail drawings. 3) Looking at the column application plan, it can be seen that curtain P04 is correctly connected to curtain P02, but not correctly connected to curtain P01. I would appreciate it if you could give information about the source of these problems. Good work. Best regards.
