curtain and beam do not join???
abdullah-70
curtain beam problem.png[/attachment]Hello, I tried to combine my curtain and beam, but the image is distorted. What do you think is the solution?
"abdullah-70":1wm96ygm" said:
curtain beam problem.png[/attachment]Hi, I tried to connect the curtain and my beam, but there is a visual disorder. What do you think is the solution?
Hello, please check the connection point of the beam to the curtain .Beams should be connected to the curtain from internal joint point in rigid direction. If connection is correct, please add your project.
I am doing my curtain-beam connections in this way, I wonder if it is a correct model. After the analysis, there was no error in my curtain groups and beams, I saved and exited, it gave an error in the curtain headers, there was no such error in my beams, there were too many of these errors in my beams. can you help me ? The error that does not appear after the analysis is recorded, and when it exits and then re-enters, it gives an error, and when the analysis is done again, the errors disappear.
"hhaticeakca":19c6smvp" said:
I am doing my curtain beam connections this way, I wonder if it is with a correct model, after the analysis there was no error in my curtain groups and beams, I saved and exited, it gave an error in curtain caps, there was no such error in my beams, my beams were too much this When I look at it, this error appears on the beams connected to the curtain, can you help? Can you help me? The error that does not appear after the analysis is recorded and when I re-enter it, it gives an error. When you analyze again, the errors disappear.
Hello, There is no problem with the curtain beam connections in the pictures you added. After the analysis ( ab) can you attach the idecad project file with the warning disappearing?
