Good work everyone, I need to do a performance analysis of an existing building for my dissertation. I have an architectural and static project in hand. After drawing the static project in idecad, I make the reinforcement arrangements, but some problems arose; 1- After entering the stirrups in the columns, the reinforcement gave insufficient (As-) errors in all columns 2- The reinforcements were also insufficient in the floors, there are also the cross reinforcements given in the project in the console floors, I think it is called tearing reinforcement, I am not sure how I can enter them in accordance with the project and as in the project If I do not enter diagonally and add additionally in x and y directions, will it replace the same diagonal reinforcements? 3- Does the insufficient equipment in the performance analysis affect the results of the performance analysis? After all, I enter the accessories as they are in the project. 4- We can determine the distance between the bottom of the stirrups in the program, but can I change the spacing of the stirrups at the upper end of the column? For example, in the project I have, the upper tightening zone is 64 cm, the middle zone is 51 cm, and the program determines them as 60 cm and 55 cm. Thank you for your answers in advance.
