emrahgokdemir
Member
Hello there. In İdecad v10.20, when I export dwg, dwg and .ctb files are created. But when I try to open the .ctb file, it gives an error as seen in the attached pictures. At the same time, when I open the drawing in autocad, my ctb file in question does not appear in the list in the plot menu, even though I copy the resulting ctb file to the relevant folder with the manage plot styles command. But when I open the same model in idecad 8.62 and export dwg, the .ctb file is opened and there is no problem. - I uninstalled and reinstalled v10.20 and the problem did not go away - I ran the program by holding down the ctrl and shift keys and double-clicking on the desktop icon, and clearing the rehistory entry and settings. - I installed idecad v10.20 on a different computer and tried it on that computer, the problem was not solved. I think that the problem is not computer related since the problem is not solved by reinstalling the program and switching computers. Since I did not encounter the same error in version 8.62, I think the problem is caused by version 10.20. I would appreciate it if you could help
