Cross Error
ebasakin
In my attached project, I cannot add a side cross to the structure. The program draws incorrectly. I couldn't provide the pmm ratio in the two scissors in the middle. Could you please check the project in terms of data entry and economy?
Hello there; It seems that a process you did in the modeling in the set you used in the project caused a breakdown. If you open a new project and make transactions, you will not encounter such a problem. We have created an example, you can make the necessary arrangements and use it according to your axle values in the appendix. However, we strongly recommend that you watch the training videos for steel.
Good work.
