Creating Dwg as Layer in Drawing
kyuceturk
Hello, I searched the forum but couldn't find the exact answer I wanted. I prepared and arranged the mold plans of my project. Then I exported it as dwg, but the whole drawing was gathered under one layer(standard). But this situation creates a big problem when I want to make some detail edits (hatch etc) in autocad. Is it possible to create the drawing divided into Layers? Thanks
Thank you Mr. Levent, then I need to export from the drawing I created, not the layout I created in idecad. Is it true? When I collect and export the mold plans in a sheet, only the standard layer is created. But when I transfer the drawing, it is in layers as you said.
"kyuceturk":311j96pd" said:
Thank you, Mr. Levent, then I need to export from the drawing I created, not the sheet that I created in idecad. Is it true? When I collect and export the mold plans in a sheet, only the standard layer is formed. But when I transfer the drawing, what you say is
Yes, the layout block has been developed to prepare the drawing sheet to be sent to the plotter.
