Couldn't fix tiling errors
a_kahveci
Hello, I couldn't fix the tiling errors in the project that I threw in two parts due to its size, can you help? It also gives zg error on the raft, is it possible to fix this error by taking the ground safety 15? Anyone know what to try?
Re: tiling problem.. These tiling errors do not go away.. If anyone has information, I would be grateful if they could reply.. also lately the analysis has started to take a long time, the same projects used to be finished in 20-30 seconds, now it takes 2-2.5 minutes What do you think it depends on? Does the pc need to be formatted or will reinstalling the ide solve the problem? Have you encountered such a problem?
"a_kahveci":1wffphqf" said:
Hello, I couldn't fix the tiling faults in the project that I threw in two parts due to its size, can you help? quote]Also, it gives a zg error on the raft, is it possible to fix this error by taking the ground safety 15? Does anyone know what to try?
If your ground safety stress is 15 tf/m2 and the Soil group is A, B or C, Analysis Settings / In the Foundation-Soil tab, the option "Increase the soil stress by 50% when using earthquake loads" can be checked. TDY article 6.3.2.1
also the analysis started to take a long time recently, the same projects used to finish in 20-30 seconds before now It takes 2-2.5 minutes, what do you think it depends on
In our computers, the project analysis time is 30 seconds. around. If you install the 8 version of the Teamviewer program and call us, we can examine the problem in more detail by providing remote access to your computer.
I fixed the tiling errors, thank you.. When the pc was formatted, the same project analysis time was reduced to 39 seconds, this is probably a normal time, thanks..
