-Data entry can be done in the pile raft foundation project as follows. -Super structure and beamless raft flooring are defined. -Piles are defined under the beamless raft foundation at the determined diameter and height. -In the Settings menu/Soil Layers dialog, the ground layers and information about the layers determined in the ground report are defined. -Reinforced Concrete/Parameters Pile type, Safety factor and other information are defined in the Pile Parameters dialog. - Superstructure interactive solution option is selected in Analysis Settings. If the beamless raft is not required to carry a load, the floor bearing coefficient is entered as zero. Analysis is done. -As a result of the analysis, the results from the Pile Foundations Report can be examined. It can be checked whether the piles can safely carry the load on them from the Pile Bearing Strength Assessment report.
