Re: GROUND STRESS Hello My suggestions; --Fix bugs in geometry check, --2. the basement floor is not rigid in both directions, remove the stiffnesses,(there are no curtains to balance against the curtains, the building torments on the 2nd basement floor. : dissolve the superstructure in three parts (with dilatation) suitable for the foundation or make the foundation one piece.(the current solution is not recommended.) When these changes are made, different results will come out. If you can't balance then we'll see. Take it easy Unver ÖZCAN
