corrupt file error
-Your project file is not recoverable. If the Backup while saving line is checked in the General Settings dialog, a backup of your project with the .bak extension will be created in the project folder. From the Open project menu, choose File type as Backed up projects(*.bak) and try to open that file. If it doesn't open, you will need to recreate it. -The ladder can be created as in the attached example.
