cork flooring
HSELCUK
Hello. I have a project with 11 floors. I want to solve it as cork flooring. There are floor gardens on 4 floors. hence low laying is required. How to act in this situation? Is there an option to solve the floors with normal floors with cork low floors with beams? I would be grateful if anyone with knowledge on this could help.
Re: MUSHROOM FLOOR Of course it can. Some floors can be made with cork and some floors with beams. If there are beams or beams on the floor and you will use the mushroom option again, you should use the column head for punching and test it. However, cork flooring has its challenges. While the load-bearing system only consists of floors and columns, chimneys and shafts usually pass through the bottom of the columns, which seriously damages the system. Sometimes, you may encounter misleading results. I suggest you be careful.
