Cork flooring reinforcement failure error
mtopac
good day guys i am working on a project and i need to solve it as mushrooms. it gives an error of lack of flooring reinforcement. I could never prevent it. I am attaching the project, I would be very grateful if you could look at my mistakes and tell me.
Hello. My suggestions: --Group the elevator curtains, --Enter the elevator engine room floor, --5. Tick the floor elevator/machine room tick, --Make slab thicknesses 25 cm, --Increase the height of the P02 curtain a little more, --Enter the slab gaps, --Increase the diameters of the floor and raft reinforcements, --Model/support the staircase and solve it together with the building , --one. It gives calculation of punching on the floor in the basement, since the console floor edges are stuck in the columns. The slab edges should not get stuck in the columns, --Make a punching calculation on all columns and see the situation, --Do not make the narrow sides of the columns 40 cm less, --4. If the floor ceiling will not be used, you can reduce the loads, -- I know the place where the construction will be done, weak ground, you can increase the floor carrying capacity by laying a stabilizer under it, Ünver ÖZCAN
Good work guys. According to TBDY 2018 4.3.4.4 article, don't vertical carriers have to be curtains in non-beamed floors? I sometimes put a few columns due to architectural necessity. Since it is difficult to make hollow floor (single-direction threaded) flooring in projects, there are requests to make cork flooring. If we can make cork flooring with so many columns, let's act accordingly. Also, is the item 4.3.4.4 (carrying all the earthquake effects by the curtains) control printed in the account reports?
"mtopac":3big9zrw" said:
Thanks a lot for your interest and suggestions, sir. Now I am reviewing my mistakes.
In addition, in the current state of your project, the floor does not connect to the elevator curtains. Divide the floor with the floor edge, (for example from 7 axis) it would be appropriate to define it as two different tiles.
