"civilng":1k8llbqx" said:I get the error iderpt.exe has stopped working when I try to convert the quantity or report files from the program to pdf format from save as.
there is pdf under the save as option"abaci09":k4bmlirj" said:SAVE THE REPORT FILE WITH NORMAL RPT EXTENSION. THEN DOWNLOAD DOPDF-7 FROM THE INTERNET. OPEN RPT FILE AND RUN PRINT COMMAND IN THE OPENING MENU PRINTER AND PRINT OPEN DOPDFY DOPF-YY YOUR FILE WILL BE CONVERTED TO PDF FORMAT. I DOWNLOAD IT FROM HEREYou do not have permission to view link Log in or register now.TWO DAYS
I say save as and choose the pdf format, it records fine, a problem no"civilng":28k6ycpn" said:I get the error iderpt.exe has stopped working when I try to convert the metering or report files from the program to pdf format after saving them differently. I wonder what is the reason for this?
I did not send the report file to Mr. Levent. Because it gives the same error in every project. I convert to pdf from another computer. The problem is mine I think it's on my computer."Admin":2kc7np0u" said:Did you send the report file you are having trouble with to Mr. Levent?
