Continuously transfers basic drawings to the standard layer
serturun
When I take the continuous foundation expansions, the continuous foundation drawings are only in the standard layer. I can't change accessories when I transfer autocade. In the last sheet of the continuous basic expansion, all layers are present, but only the standard layer is available in other sheets
Hello, After taking the continuous basic drawings and copying them into a sheet as a block, if you export the sheet, all drawings will be in the standard layer. You can make 2D Edits in ideCAD after receiving the drawings. Layers will be active. If you want the DWG to go in its layers while exporting, do not export from the layout. Combine drawings on any 2D drawing page and export the 2D drawing page.
1.-2.-3. of continuous basic expansions. There are only standard layers in the layouts. On the 4th sheet, there are all the other layers. I exploded the drawings once, and it didn't work. I blew them all. I can only send the project where the layout with all the layers is correct and the other three layouts are wrong.
