CONTINUOUS BEAM
civilng
I want to make the K3 and K4 beams behind the stairs on the A axis between 4-6 axles as a single beam. For this, I changed the beam angle difference in the general reinforced concrete parameters between 5-30, but when I get the drawings, a confused image appears.
ürekli.cde
"civilng":2rt8f0b9" said:
I want to make the K3 and K4 beams behind the stairs on the A axis between 4-6 axes like a single beam. For this, I changed the beam angle difference in the general reinforced concrete parameters between 5-30, but when I get the drawings, it looks confused. Can you help with this?
The option in the general reinforced concrete parameters is valid for column-beam connections. You can define beam-beam connections with the curved beam command by giving the number of curved points 1. We did not have a chance to examine your project because it could not be downloaded..
"HakanŞahin":2iwakyba" said:
"civilng":2iwakyba" said:
I want to make the K3 and K4 beams behind the stairs on the A axis between 4-6 axles like a single beam. I changed it between -30, but when I take the drawings, a confused image appears. Can you help with this?
The option in the general reinforced concrete parameters is valid for column-beam connections. You can define beam-to-beam junctions with the curved beam command by giving the number of curved points 1. Since your project could not be downloaded, we did not have a chance to examine it.
