CONTINUOUS BASIC
oguz atalay
Good day, I am constantly having problems with the foundations in the project I have attached. When I solve the project in the 5.53 version of the program, while the ground safety values are high (which I think it should be), in the 6.54 version, even 60-footed foundations will install the system. it also gives an error when I want to solve the project interactively with the superstructure. thanks have a good day.
"oguz atalay":1aj70tu9" said:
When I solved the project in the 5.53 version of the program, the ground safety values were high (which I think it should be), while in the 6.54 version, even the 60-grade foundations will install the system. I solved 6.54, the basic results look the same in both versions (Your project was registered at 6.54, I solved it in 6.53 with Save the project as old version). If you add the projects you see difference, we will evaluate the result more accurately. 1aj70tu9"] also gives an error when I want to solve the project with the superstructure interactively.
You must define beams TK37 and TK49 at the intersection of P23 and P28. (The conjunction was at the bottom of the columns and was skipping P23 and P25). The project that can solve is attached.
