Continuous Basic Detail Turns out to be long
gencideci
When I take the basic expansions constantly, it turns out to be long as I will give in the appendix. The screen I edit is not like this, why is it like this when I want to get an expansion? Let me just say that this project is also there. I noticed it while editing the layouts. I wanted to ask you before I delete it and lay the foundation all over again...
Hello there; If you have foundation beams that intersect at very small angles, it may be due to it. For a clearer answer you should share your model. Best regards.
"gencideci":1bidzs8s" said:
When I take the basic expansions, it comes out as long as I will give in the appendix. The screen I edit is not like this, why does it look like this when I want to get expansions? I wanted to ask you before assigning...
Hi, the long drawing of the TKZ33 continuous foundation expansion may be caused by the fact that the foundation joint point is not on the column, there is a small angle between the foundations as stated by Mr. 2m project, and it is not drawn continuously, etc. It is not possible for us to detect the problem exactly from the dwg file you added.Can you attach the project file?Good work
