Continuous basic connection with 7 versions
civil63
GOOD DAY... IN THE MAIN PROJECT IN THE 1st PHOTO, THE CONNECTION OF P04 AND S04 WAS PROVIDED WITH TK 31 STRAP... IN THE 2nd PHOTO (IF IN APPLICATION) THE CONNECTION OF THE P04 AND SO4 COLUMNS (TK31) WAS MADE WITH THE FAULT DUE TO THE PROJECT... MY PROJECT:1) SO THERE WAS ANY PROBLEM IF IT IS DONE IN THE 2nd PHOTO... WHEN I PERFORMED THE FUNDAMENTAL ANALYSIS, I DID NOT RECEIVE AN ERROR ABOUT THE GROUND EM.GER. ACCORDING TO THE 2nd PHOTO... I JUST RECEIVED 3-4 INSTALLATION REINFORCEMENT LACK ERROR...
It is appropriate to input data from the curtain nodes of the continuous foundation nodes and to be a continuous basis under the curtains.
Mr. YoLevent, the zg value of Tk06 Tk 07 is smaller in the first case...would it be a problem if it is done as in the first case...thanks...
"civil63":301zqkbo" said:
YoLevent Bey, Tk06 Tk 07 zg value is smaller in the first case...would it be a problem if it is done as in the first case...thanks...
In the attached picture, the continuous foundations are not attached to the curtains looks.
