Continuous base reinforcement quantity
ilhan27
take it easy, in the attached project, the reinforcement quantity pertaining to the continuous foundation is 38 tons. With sta4cad, its solution was made with a 14-ton reinforcement. I would be happy if you could take a look at where the error is coming from and if there are any other errors in the project that you notice, I would appreciate it.
Hello there; Your basic data entry is completely wrong! You should enter data so that your continuous foundations are on the columns and all your different foundation beams will converge at the same point if possible. If necessary, you can align the foundations by giving different offset values. If necessary, watch the training videos of the ide structure on Youtube. Due to incorrect data entry in your project, your TK265/TK277 / TK278 numbered foundation beams are perceived by the program as being too long. This situation causes the quantity to be excessive. If you get the foundation beam drawing you will see the error. When the basis for incorrect data entry is corrected, the quantity 12ton is obtained. Best regards.
