Continuity of foundation
civilization
Hello there. In the attached project, it doesn't happen all the time when I'm building the foundations that I took into the cloud in the basic part. what is the reason for this? Sometimes the same thing happens to me with the beams. In these basic expansions, one side also gets longer after the column. what is the reason why the program sees these beams as discontinuous and how can i fix this situation.
Fundamentals are not the same from the perspective. Putting it in the same direction from the point of view as the base beam direction command will fix the problem. See attached pictures. N. YILMAZ
"NYILMAZ":11jz72bk" said:
Foundations are not the same direction from the point of view. Put it in the same direction with the base beam direction determination command and the problem will be fixed. See attached pictures. N. YILMAZ
thank you very much.
