Console Beam problems, if you post a sample project and comment, please
Karmnl1158
Friends, there are problems with the length of the console beam. If we give an example; It depends on the project, but you may say, how will the cantilever beam exceed 1.5 meters (moments, load transfers, deflection, shear force) exceed one and a half meters (for example, how should a 3 m console be designed in any project), but you will go into too much detail, but what about idecad cantilever beam calculations? How much should we trust?
Re: Cantilever Beam problems, if you post a sample project and comment Hello, the program performs all necessary checks on cantilever beams that exceed 1.5 m or not. Modeling the project depends on engineering experience and knowledge, and modeling the console is the same. There is no such magic formula. The program is reliable in the console and other parts. It is important to use the program knowing what it does. The program should not be used with the logic of I did it. Take it easy Unver ÖZCAN
