"engineer_yildiz":2s76jns0" said:
Dear Idecad family, In the same İdecad installations, Computer hardware difference is the calculation of the Idecad program. (static analysis and reinforced concrete)? He states that when the projects submitted for control are reopened or analyzed on the computer of the controlling authority, the user detects errors/warnings on our computer while there is no problem on his own computer. Could this be due to hardware differences?
Hardware differences do not affect the static analysis and reinforced concrete results of the program. The same project data gives the same result no matter which computer it is decoded. Reinforcement and size changes made in the reinforced concrete dialog, stirrup spacing, stirrup diameter etc. changes, subsequent reinforcement fixation will affect the element bearing/shear capacities and may affect the earthquake code controls in the next analysis. This can change the warnings of critical elements. For a definitive answer, it is necessary to examine the project that is thought to be free of errors. Did you have the project re-analyzed on the project's computer, which gave a warning/error when you analyzed it?
