composite flooring
dogukan
Hello, I made a simple frame, I defined its tiling as composite. All elements were inspected, but I could not see any evaluations such as deflection control of composite flooring, only deflection control was made for composite beam. I couldn't find where I can see the evaluation of the flooring or is there a composite flooring evaluation in the program? Thanks good work.
Hello there; In case of a composite slab definition, the effective width and depth values of the steel beam and the concrete on it are determined, and the composite design of the steel elements is made. No deflection inspection is made for the flooring.
Thank you for your answer, but I have one more question. I need to calculate how many tons of load the flooring I have defined can withstand, can you help with this?
