I can't get the drawing of the mezzanine that I drew as steel. the drawing of the secondary beams does not come out at all. I could not load the project. please make an urgent return
Hello there; While creating your project, you did not make any definition for the level where the floor is located from the floor general settings. Therefore, for the details of that level, you should make adjustments for the level where the floor is located in the form of steel drawing settings - plan settings - add - 450 cm.
