Hello there; ideCAD Steel & Reinforced Concrete 8.62; As I mentioned before, in the determination of earthquake loads, it correctly performs the process of combining earthquake effects in perpendicular directions for both reinforced concrete and steel. There is a difference in display results at the interface between reinforced concrete and steel. If we make a detailed explanation for steel; - First of all, the values you see in the section effects in the analysis results are the raw results. Design results obtained by combining them and, if necessary, increasing with other factors specified in the earthquake code; are shown in the details section of the design screen of the elements. To explain this with an example, the results for g loading, Ex, Ey and G-0.7Ey, which gives the most unfavorable pmm ratio in design, can be checked in the images below. **** In short, the analysis is carried out in accordance with the Earthquake Regulation for Steel. If we come to the other subject, Strong Column - beam; - This control is carried out on moment-transmitting frames bearing earthquake load. In your model, the joint is defined in your weak beams. If the program contains hinges, it does not perform strong column - beam verification. If there is a joint at the end of your beams connected to a column, that directional moment is taken as 0. The values of 0 seen in the report are as follows: i) Since it does not represent the mechanism of the elements that are weakly connected to the column in moment-transmitting frames, 0 is continued. In short, they are not included in strong column-beam control. Good work.
