hello, is there any shortcut setting in drawings? For example, the autocadde right button was set as the last command, or a letter that we want to delete, move, copy, could be done. Can such a thing be done in the idecad program? If so, from which toolbar can I set it?
hello, is there a shortcut setting for drawings? For example, autocadde right button was set as the last command or a letter that we want to delete, move, copy, could be done in idecad program, if so, from which toolbar can I set it.
Hello, You can assign keyboard keys to commands in the classic menu layout. To switch to the classic menu layout, uncheck the "Ribbon menu" line from the Settings / General Settings dialog. Exit the dialog by saying OK. Close the program and reopen it. While the classic menu layout is active, you can perform the shortcut assignment as below. You can do as described in the link
