eissenhover
Hello, I found 18 combinations for reinforced concrete and 27 for steel in idecad, I may be wrong, when I examined the combinations, positive and negative directions were determined for the wind, but there are only Ex and Ey values for the earthquake, there are no positive and negative directions, the existing combinations buried in idecad Do you think it is enough or do we need to add additional combinations as users, and why didn't the positive and negative directions be determined for the earthquake and worked into the combinations? Thank you in advance for your answers. In addition, when will the idecad version compatible with the new earthquake regulation be released? We, licensed users, will update the price difference and move to a higher model (in line with the new regulation), not like buying from scratch, is it true?
