Combination with T plate and Single slip plate
serdagi
Hello, from the attached pictures; 1) In the connection with T-slip plate, the main profile is drawn short, the bolts are left free. It is seen in the same way in the post-analysis drawings. 2) I can't cut in a joint with a single slip plate. I ask for your help, I wish everyone a good work.
Hello there; You must enter values for the d1 and d2 parameters in the upper and lower notching tabs in a single slip plate joint. T-profile connection is generally used as beam - beam connection in the program. If you enter between column and beam, you can edit with the parameter in the image. Joint geometries have nothing to do with analysis. You have to edit the geometry of the join with the parameters in the menu. Good work.
