Columns are not visible in the column application plan.
Pandora
Columns do not appear in place in the column application plan of a reinforced concrete structure that I analyzed. their places are crossed with other columns how can i fix it
Re: help
"Pandora":33cft3o2" said:
columns do not appear in place in the column application plan of a reinforced concrete structure that I analyzed. Their places are crossed with other columns that have slipped, how can I fix this
Application plan and column detail scale Since the details are different (default values 1/50-1/20), the details may overlap. If the "Always detail outside in the application" option is checked in the Static/Reinforced Concrete tab of the properties of the overlapping columns, the columns will be drawn without reinforcement and at the same scale as the application plan, reinforcement details It will be given outside separately. If you attach the project file, we will examine it in more detail. Good work
