column vs curtain
yunussacikk
The length of my curtains around the stairs and elevator is 190 cm. The thickness does not save when I make 25 cm ....25 cm thickness. Now when I increase the thickness to 30 cm, my curtains do not add columns to my curtains. program
By column, you mean the curtain end area. You should make a 30/190 size column. Also, if you put a picture or project file in your building, you need to look at why and what a 25/190 elevator curtain does not save.
