column vertical expansions.
bartayd
Can we adjust the distance between the column detail and the column sprout detail next to it while taking the drawings of the vertical expansions of the columns? Also, the elevation distances on the column sprout detail are outside. Good luck with.
Yes, regarding this issue, I often feel the need to break apart the blocks of vertical column expansions and bring both the reinforcements and the elevations closer together, it becomes more tidy. As far as I know there is no setting for this.
