COLUMN STRIKE TIGHTENING SETTINGS
murat mungan
I WANT TO EXTEND THE LOWER COMPRESSION ZONE ON FLOOR COLUMNS, THAT IS TO CONTINUE AFTER THE SURFACE CURTAIN, IT IS POSSIBLE TO ADJUST IT MANUALLY.
In the lower part of the colon, the tightening is up to 1.5*lb and is done automatically. Apart from that, the length of the compaction zone can be intervened after creating the vertical expansion of the column in the 2D environment.
Is it possible to add an option in the new version? It is quite a time consuming job. (1.5*lb + bulkhead height manual)
"oyuxel":3ifa11mv" said:
is it possible to add an option in the new version? it's a very time consuming job (1.5*lb + height of basement screen manually)
Your request has been registered in our work list. Thank you for your attention.. .
(1.5*lb + height of basement screen manually) In addition to this, sometimes there is very little distance left after tightening at this length. In this case, it is more logical to tighten in that area. In addition to the option, full stirrup tightening of the beams we want is done, as well as tightening all the columns we want in the columns. I think it will be much better if the opportunity to throw stirrups is provided at intervals in the region.
In the new version, we have made a change that will automatically consider the lower condensation zone of the column starting from the upper level of the connected sub-basement curtain. We have also added the possibility of intervening in the length of the lower compaction zone in the columns you deem necessary. In this case, you will be able to define all of the column stirrups you want as compacted by giving the length of the compaction zone as much as or more than the length of the column.
"Admin":2jggould" said:
In the new version, we made a change to automatically consider the lower compaction zone of the column from the upper level of the connected sub-basement wall. We also added the possibility of intervening the length of the lower compaction zone in the columns you deem necessary. In this case, the compaction zone length is equal to the length of the column. You will be able to define all of the column stirrups you want by giving them more or more.
Hello; In the update you mentioned about the basement curtain, is the column free load, which will affect the column shear safety control, is calculated by taking into account the "ln" basement curtains? Otherwise, the update only affects my drawings. . Best regards.
In the calculation of ln, the condition of the basement walls connected to the column was taken into account.
