profesyonel
Hello, in my attached project and the like, I cannot see the clear height of the basement floor and the ground floor, column shear safety control separately. The column gives the clean height according to the total floor height of the basement and ground floor. I get the same result if the sub-basement is rigid or non-rigid. Even solving the project as tamrigit or shell does not change the situation. Building inspection companies want to see the clear height of the basement and ground floor column separately in the column shear force control, but they create problems because they write the total height. I request you to revert to the issue. good forums
