Hello, What caught my eye: - You have chosen the ductility level as normal, but the R coefficient appears to be 7. - By choosing a semi-rigid diaphragm in the analysis, analysis together with the flooring is more appropriate. - There are columns that do not save axial capacity, their dimensions should be increased. - It is important to have curtains in both directions in hollow blocks. Curtains should also be added in the Y direction. - Concrete strength of C30 helps with column dimensions. In addition, this 7-storey building has columns that exceed the required - Stapling strength. Foundation thickness should be increased or column dimensions can be adjusted.
