Hello, the values shown in 3 dimensions are the raw values obtained as a result of the analysis. Reinforced concrete design is the values that are enlarged as required by the regulations. In the reinforced concrete dialog, you can select as design results and raw results. As one of the new features that came with version 10, there are two results with + and - eccentricity in Ex and Ey earthquake loading results. In the reinforced concrete dialog, Ex, Ey values do not appear as two values, but as a single maximum value. As a result of this, 4 different values are processed in the background in combinations as Ex + 0.3Ey or Ey + 0.3Ex, the most negative of these values (the combination that creates the most reinforcement requirement) appears in the design. In the table where all the results are shown in the reinforced concrete dialog, the maximum values of the relevant combination are shown. This may not always be the most unfavorable situation (especially since two-way bending calculations are made under axial force in columns), but it may be one of the different combinations processed in the background. In your example, the combination based on the column calculation has been one of the combinations processed in the background.
