Column pull will taste pressure fracture
Frkninşaat
Dear forum officials, my dear colleagues, where can we learn about İdecade column pressure or tensile breakage? Thank you for your attention. Best Regards.
"Frkninşaat":jmpcktdw" said:
Dear forum officials, my dear colleagues Where can we learn about İdecade column compression or tensile fracture Thank you for your attention Best Regards
Hello Whether the column is under the influence of axial tensile force or not in the Column Reinforced Concrete dialog/Force Reinforcement Fields tab, Design You can see it by looking at the sign of the F1 (axial) force consisting of loading.If the sign is positive, the column is under axial tension. Good work
"Frkninşaat":1gqazp68" said:
Dear forum officials, dear colleagues Where can we find out about İdecade column compression or tensile fracture Thank you for your attention Best Regards
Hello, Design axial compression force in columns is limited in TDY and TS500. If this limit is If it is exceeded, the program warns you.Therefore, pressure breaks never occur in the columns.Reinforcement design is made to prevent tensile breakage in the columns.
