I am using v6.53. How can I change this in making scans very tight on columns and panels? When the output is taken, it looks very dark and the name of the panleer is not read.
V6.53. It makes scans too tight on columns and panels, how can I change this? When it is printed, it is too dark and the name of the panleer is not read
1- Before I get the pattern plan Layer Column and panel scanning can be turned off in Settings/Drawing details tab 2-After receiving the pattern plan, column and screen bitmap scans can be changed to user-defined scanning (Scan/Bitmap Scan click command. Click ]Select all . All bitmap scans will be selected. Click Object Properties . In the dialog that opens, select an appropriate raster type from User defined scan tab.) 3-Folds Screen name and size can be printed outside the screen in the Texts Tab in the Screen Settings dialog in the screen.Note: We recommend updating Ver 6.54.
