column major minor vertical expansions
Hello, The process of getting vertical expansion in the minor direction has been removed in column vertical expansion. A general algorithm is applied for similar columns in the same and/or different floors, which takes into account the columns of the whole building. If you write your reason for taking the column vertical expansion in the minor direction, we will make a more useful evaluation. You can provide an example if needed. Good work
In a reinforcement project, I jacket one side of the columns, for example 25/50 becomes 25/80 with a column jacketing. In column vertical expansions, I want it to expand based on the 80 dimension, but the program gives the vertical expansion according to the 25 dimension. that's why the iron reinforcements placed on the sheathing side are not visible in vertical expansions..or for example, I'm sheathing in both directions, I want vertical expansions so that I can give the expansion of both directions..
Hello, we can't always get the smaller part on the upper floors while the column expands vertically. This feature was also available in the older version. Can you help with this?
