Column Head
inş_müh
I am solving a beamless slab project for the first time with idecad 7. I cannot add the column header. When we enter the column header tab from the reinforced concrete tab, the column dimensions are written here and I cannot play. Also, what dimensions do we have to leave. I would appreciate your help.
You are logging in from the wrong place. You will use the column/column header/ commands for the column heading. See attached pictures.
Thank you very much, but there is a beamless flooring project that I am stuck with in general. I need to pass the attic with beams. I will be glad if you help.
Hello. My suggestions: --1. you do not have flooring on the ground floor, --1. Dilatation in the basement is not like this, --The floors are at the same level. --The floor I marked is console, it does not press on the inner columns. --There is a gap on the floor on the floor --Fix the places I gave, --Fix the errors in the geometry control. Let's see what happened later. Good luck with. Unver ÖZCAN
