column facing the sky
201968
In order to continue the elevator curtain as a column on the roof (facing the sky), I need to define a column with a width of 25 cm. In the report section, I get the error TBDY 2018 7.3.1.1 "The smallest cross-section size of rectangular columns cannot be less than 300 mm". How can I turn off this error from the report section for the sky gazer? Is there such a possibility?
Re: SKY LOOKING COLUMN
"201968":ygy4r83u" said:
I need to define a 25 cm wide column in order to continue the elevator curtain as a column on the roof (facing the sky) TBDY 2018 7.3.1.1 In the report section, I get the error "The smallest cross-section size of rectangular columns cannot be less than 300 mm". How can I close this error in the report section for those looking at the sky? Is there a possibility?
Hello, If the elevator curtain does not provide the ratio of 1/6 on the attic floor, you can define it with the Curtain command so that it does not give a warning, and select the option "Base-floor-discontinuous curtain on all floors" from the Curtain properties. You can check the "Short title pitch" option in the " tab. Good job
