column drawing
gunay.17
How can I draw the column in the picture? I tried to draw the polygon as a column, but I couldn't quite fit it.
In autocad, you can measure the angle and give the same angle, use a continuous line, complete the remaining 3 corners and turn it into a polygon column
If the subject you are talking about is related to layout, you can define from the corner point, draw an oblique axis parallel to the edge and paste it on this oblique axis. No, if you mean [/u][/b] in terms of the shape of the column: 1- You make the polygon as a column and place it in its place. 2- Define a rectangular column, you can get the shape you want with the column trimle command. 3- For me, this column is a rectangular column, I don't bother with any of it. I make the calculation as a rectangular column and then make the column that way with 2D drawings. N. YILMAZ
